hardware ???
hardware ???
I'm doing an a4 to manual swap, just ordered the ls7 clutch and ls2 flywheel.. Will my old bolts that mount the flexplate to the crank work with the ls2 flywheel...and does anyone know what the part number for the arp bolts that mount the pressure plate to the flywheel, and how many there are..
should I use blue loctite on the pressure plate bolts, or the flywheel bolts
just found these part #'s on summit
flywheel bolts- arp-200-2802
pressure plate bolts- arp-130-2201
will these work for me
also are the tranny crossmembers different between the manual and auto
I'm curious about ARP replacement bolts for the flywheel and pressure plate. Those that you listed aren't metric though. Did you ever find the correct part numbers?
EDIT:
Never mind, Thunder Racing does list those as the correct metric replacements. Did you get these to work correctly on your LS2/LS7 clutch swap camaro383?
113-134-2201 ARP LS1/LS6 Pressure Plate Bolt Kit $16.99
113-330-2802 ARP LS1/LS6 Flywheel Bolt Kit, 11mm $26.24
EDIT:
