clutch pedal?
Old 01-20-2006, 03:38 PM
camaro383's Avatar
Default clutch pedal?
I purchased an m6 pedal assembly off of ebay and put it in my car and was gonna cut the hole for the master but it seems it is slightly bent and the mounting holes for the master don't fit right up against the firewall, so I have to force the bracket against the firewall....I just want to know if it will effect the master if it is not aligned up perfect like how it is from the factory...does it matter if the clutch rod is at a different angle???
