Striped The Crank Threads!
well, I was putting on the spec flywheel with the bolts that came with it (shorter than the stock ones) and I was torking down the 1st bolt and that's when it happened... the wrench spun freely! ouch. I took out the bolt and replaced them with the old ones, I think the old bolts are in good threads by about 1/2 inch, and they torked down tight enough to make the torque wrench click, so I think I'm okay... What do you guys think? Anything to worry about?
