OEM clutch questions?
OK well my stock clutch is ready to die so Im trying to decide which one to get. Ive was planning on getting a Z06 clutch but then heard people were using LS7 clutches in F bodies. So my 2 questions are-
1. What is the part number for a Zo6 clutch that will fit in a F-body
2. What all is needed to put a LS7 clutch in a F-body and part numbers would be very much appreciated if anyone has already done it
Thank you
Thank you
I can look on my boxes tonight for the part numbers. I am in the middle of this clutch change right now. I am replacing all Hydrolics, Flywheel and Clutch. The Flywheel is a LS2 Flywheel. Do you want part numbers on all parts?
Originally Posted by kenp
LS7 PP & disc # 24233650
LS2 Fly wheel # 12571611
When you say ZO6, that doesn't tell us anything. In 2004 the ZO6 Corvette had an LS6 engine. In 2006 the ZO6 Corvette has an LS7 engine.
I think you've meant to say LS6. Yes, an LS6 clutch bolts right in to an F-body with or without a change in flywheel. Sorry I don't know the part number. You should call Fred Beans or Scoggin Dickey and they will take care of you.
