P0704...guys that have done the A4->M6 swap
Or anyone else of that matter. Has anyone seen this code before?
P0704 - Clutch switch circuit
I know I wired up the clutch switch correctly (black switch). I still don't have cruise control though so I'm thinking this is related to the SES being thrown. Anyone want to point me in a direction. For some reason I was thinking that there was suppose to be another switch connected (back of clutch pedal) but there's no wires or connector to plug into it.
Any help would be greatly appreciated.
I did the swap and had the same prob with the cruise and others. This is the write up I did to fix the problems.
A4 to M6 Wiring Repairs
Ok, here's what I found out, I am missing the connector located on the back of the clutch pedal. I know b/c the guy that I swapped out my A4 to M6 with said he had a plug that was just hanging there. I'm pretty sure that's what I need to get my cruise to work and to get rid of this SES light.
So here's my next question, when I plug the connector in, I'm just going to have wire's dangling there. I need to know where to run those to? Maybe route them up to the PCM or can I tie them into other wires and make them to work?
