Flywheel Question
Flywheel Question
I just bought a Z06 clutch and pressure plate. My question is do you have to have the Z06 flywheel in order for it to work or can you use the stock ls1 flywheel? Is there a difference in flywheel width between the two? I've read in vette forums they use the fidanza and other aftermarket one's. Just curious to find out if it will work with a stocker. Thanks.
