New to transmissions, gotta few questions..
Old 02-07-2006, 12:17 PM
Syxx613's Avatar
Default New to transmissions, gotta few questions..
hey guys i have a few questions. my first is this.. in this first pic im showing, what is #1 and #2? and in pic 2 whats the blue hose for and am i missing anything? thanks!
Old 02-07-2006, 12:32 PM
calhoon's Avatar
1 is the skip shift solenoid electrical connecter.
2 is the bore wher the speed sensor should reside.
pic 2 blue hose....It is not a trans part but Ill play the game:
Its an air line from your power tool.
Its one of those old line you run over at the gas station to make the"ding"
Its a King Kong jump rope.
Is it an insulated CSC feed line? You don't show where its attached so Ill guess the CSC.
Old 02-07-2006, 12:44 PM
Syxx613's Avatar
ok cool. are the skip shift and vss on the engine wiring harness or a different harness? here is a pic of where the blue hose connects..
and what is it? what does it do? thanks!
Old 02-07-2006, 02:32 PM
DONAIMIAN's Avatar
If that first one is on the drivers side or the tranny under the shifter, then its the reverse lock out.
Old 02-07-2006, 02:39 PM
Camaroholic's Avatar
Hose is a vent tube. Yours is not stock. Stock is a hard black plastic tubing line. If you put too much fluid in the tranny, that's where it goes when it gets hot.
Old 02-07-2006, 02:41 PM
DONAIMIAN's Avatar
or in my case comes in the car through the shifter I really need to get under there and make sure its not blocked.
Old 02-07-2006, 06:36 PM
Syxx613's Avatar
ok thanks guys! are these electrical connectors on the engine wiring harness or on a different harness?
Old 02-07-2006, 08:04 PM
gettinthere's Avatar
They'll be on the main harness.
Quick Reply: New to transmissions, gotta few questions..
