Clutch help
Clutch help
Ok, so i had this posted in the temporary site, and of course lost it all. So, here it is again. My car is in my sig, and the clutch is slowly going out so i will need to replace it early summer. What would be a quality daily driver clutch with better performance than stock. Also, i am a college student so money is somewhat tight, so no super expensive clutches.
Thanks!
Thanks!
I hear good things about the LS6 clutch or the LS7 which would be the closest to stock driving, I got a Spec 3 and it drives good was goin w/ a LS6 but buy the time you bought everything the Spec was a lot cheaper
Kleeborp the Moderator™
Oh...so you were actually serious over on the beta site. Yeah. Don't go off that advice.
If you are going with a Procharger (although if you are on a tight budget, that won't be for a long while), get the LS7 clutch with the LS2 flywheel.
Otherwise, just get a replacement LS6 clutch from one of the fine sponsors on here (SDPC is good).
A guy from a shop here in town is reccommending a centerforce clutch, would that be a good daily driver/performance clutch that could hold the 500+ hp with a procharger?
