Torque specs...
Torque specs...
Does anyone know the torque specs for the bellhousing bolts and the bolts that connect the tranny to the bellhousing?
Does anyone know the torque specs for ARP pressure plate bolts? Loctite?
I also have ARP flywheel bolts and the instructions only say to use arp assembly lube, should I use loctite also?
