shifting problems!!!.. need help
Old 03-02-2006, 09:40 PM
2002blkss's Avatar
Default shifting problems!!!.. need help
i just installed spec 3 clutch and fidanza flywheel and trex cam, when trying to shift it wont go into gear i dont know if its b/c im at such high rpm's or if something else is wrong any info will help... thank you!
Old 03-02-2006, 10:18 PM
CW00BlackTA's Avatar
Where is the clutch pedal engaging? Are you sure you bled the system well?
Old 04-22-2006, 10:07 PM
SSPerformance's Avatar
did u ever slove this problem im haveing the same with my spec stage 3
