doind the clutch and hydraulics, what else?
Old 03-06-2006, 11:10 AM
30th TA 0219's Avatar
Default doing the clutch and hydraulics, what else?
Have the LS6 clutch kit, updated master and slave, and 4 quarts of Honduh Z1 ATF.
What else do I need? Pilot bearing? T/O Bearing? Neither is included with the GM LS6 kit right? I'm assuming neither is REQUIRED to be replaced, bu since I'm in there...
Any avoidable pitfalls? I've checked out Install University already!
***EDIT***
My NEW GM 288 Slave comes with the TOB, doesn't it! DUH!
Old 03-06-2006, 08:03 PM
CW00BlackTA's Avatar
Yes, replace the pilot while your in there and don't forget to rent the pilot bearing puller.
Old 03-06-2006, 09:37 PM
wrencher
wrencher's Avatar
Drill mod do it while your there.
Old 03-07-2006, 01:00 AM
screaminbird's Avatar
If u got the upgraded slave it will have the new T.O. bearing already on it too.
Old 03-07-2006, 02:23 PM
no, I'm good on the newer factory one!
4 hours in, and just getting the trans and b/h off! And now my help went home!
