Master Cylinder Removal
I searched but didn't find anything. I am trying to replace my master cylinder and i can not get my hands in there to remove the hydrolic line that runs to the slave cylinder. Is there some trick to removing that pin that i am not aware of? Help please!
in order to do it, your gonna have to remove the entire master cylinder. not just the line. you have to push the white thing on the quick disconnect fitting that goes into the slave in, removed the line, remove the heat shield to get the line free, then remove the master.
http://www.installuniversity.com/ins...sity/index.htm then click on install documents and scroll down to drill mod.
