Spec stage 5 soaked with brake fluid
Old 03-09-2006, 02:04 PM
Silver Slayer's Avatar
Default Spec stage 5 soaked with brake fluid
I just pulled my transmission and found out why it was slipping. I had brake fluid in the bellhousing and if got the clutch and pressure plate wet. Since it is the stage 5, would I be OK just cleaning it off with brake cleaner and letting dry real good? The clutch is still in great shape, practically new. I am looking to sell it, but don't want to sell it if it will not work properly.
What can I do?
Thanks,
Kevin
Old 03-10-2006, 06:18 AM
Anyone?
Old 03-10-2006, 02:43 PM
Miguel_in_Denver's Avatar
check your slave cylinder.
Old 03-10-2006, 03:17 PM
bigdsz's Avatar
Call SPEC and tell them what happened.I would think if you spray everything with brake cleaner all would be good, since the disk is sintered metal.
Old 03-10-2006, 04:11 PM
buschman's Avatar
I would bet brake cleaner will work fine. I also agree your slave cylinder is probably the cause of this.
Mike
Old 03-11-2006, 12:30 PM
Yeah I was thinking about it later and I agree. I know I bled it a lot, but since there was no way for the fluid to get out this probably only added to the slave leaking.
Thanks,
Kevin
