Jumping Out Of 4TH Gear - LS1TECH
Thread Tools Search this Thread
Old 03-14-2006, 01:41 PM   #1
LS1ROPER's Avatar
Default Jumping Out Of 4TH Gear
NEW CLUTCH,REBUILT TRANS,UP SHIFTS GREAT BUT WHEN YOU DOWNSHIFT FROM FIFTH TO FOURTH IT JUMPS OUT OF GEAR.ALSO,SLOWING DOWN IN FOURTH IT WILL JUMP OUT OF GEAR.EVERYTHING ESLE IS FINE JUST SPITTING OUT OF FOURTH GEAR.TRIED MOVING GEAR STOP BACK ON SHIFTER IN FOURTH & BLED THE CLUTCH SYSTEM OF ANY AIR BUBBLES! DONT KNOW WHAT ESLE TO DO. ANY SUGGESTIONS?
LS1ROPER is offline   Reply With Quote
Old 03-14-2006, 11:48 PM   #2
89Formulaws6's Avatar
Quote:
i have a few obvious things but worth checking
check the linage,is the trans case lined up properly and tight?
was it professionally rebuilt?
89Formulaws6 is offline   Reply With Quote
Old 03-15-2006, 03:57 AM   #3
LS1ROPER's Avatar
Yes alignment is good and trans is tight.Yes trans was rebuilt by a sponsor.
Old 03-15-2006, 04:12 AM   #4
EPP
I would call whoever rebuilt (or had it rebuilt) for you, and explain the situation. It sounds like an internal transmission problem to me. Bob
EPP is offline   Reply With Quote
Old 03-15-2006, 10:56 AM   #5
Quote:
agreed possibly the syncro wasn't put together right maybe
Old 03-15-2006, 12:32 PM   #6
KilerTA's Avatar
i had the same problem in my 00ws6 i kept jumpin out of 2nd and reverse i had to get new syncros and forks on thoses gears. if i can get pics of the old syncros i can show you why they jump outa gear its kinda neat
KilerTA is offline   Reply With Quote
Old 03-15-2006, 12:45 PM   #7
it could even be the shift fork as well. I didn't think reverse gear wasn't syncronized but i don't know alot about the t56 yet only the t5.
simple things during putting the mainshaft together have cause a syncro to get messed up, the inserts not properly seated, lock rings not put in right, even the syncro sleeve not put on right. too many to list
Related Topics
Thread Thread Starter Forum Replies Last Post
t56 stuck in gear. or it it? bumpin ben wallace Manual Transmission 0 04-25-2015 05:15 PM
Stuck in fourth? HELP!?!? 01Sidewinder Manual Transmission 23 06-28-2010 06:06 PM
Stuck in fourth!!! lilmiller74 Manual Transmission 13 04-20-2010 04:18 AM
My Fourth Gear Went Out Help! svtthis16 Manual Transmission 10 05-14-2008 08:36 PM
I think I bent a pushrod. 99silverWS6 Generation III Internal Engine 7 06-07-2004 01:25 PM
Tags
2000, 4th, car, gear, jump, jumping, jumps, km145, manual, t444e, transmission, transmissions
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
