Clutch pedal problem?
I know that this has been beaten to death a million times but I dont know if I have the same problem as anyone else or not. My clutch pedal just started to act funny about a week or two ago. Usually it engages in about 1/2 inch of travel. Now, it will go as far down as halfway until it engages? If I pump the clutch up it fixes the problem but only for a little while. I know that the return spring is fine so the clutch always returns up, just sometimes a little slow. The trans still shifts fine. I have never touched the clutch system at all, and the fluid level is fine. I also noticed that on warmer days, or after driving relatively fast the problems clears up. What could have caused this? How should I go about fixing this. The clutch has abou 41K on it and it is a stock 01. It has had about 400rwhp on it for the last 15-20k if that helps. Let me know what you think. thanks.
Sorry for hijacking the thread but I'm pretty new to the whole M6 world (just did a swap). But where exactly is the pedal suppose to be engaging/disengaging? I thought I read 2-3" off the floor which is where mine is at. But I've heard that it's suppose to be halfway up. Someone please tell me which one is correct.
