Need a clutch
Old 03-28-2006, 07:40 PM
8a8mfh's Avatar
Default Need a clutch
What clutch should I get for a 2002 SS? It has an automatic now, all I need is the clutch for the conversion, the car is stock and I will be replacing the 3.23 gears with 3.73's that I have ready to go in also.
I think a stock clutch would be fine but what is stock?
I found a Z06 clutch with the flywheel for $425.
Also Luk clutches, they cost about twice as much as centerforce, I don't understand.
Which one should I get for this application?
Old 03-28-2006, 10:56 PM
8a8mfh's Avatar
Can a sponsor beat $540 for the Z06 flywheel, disc, pressure plate, release bearing, slave cylinder, and needle bearing pilot?
Looks like I'll be going with a non sponsor.
Old 03-29-2006, 06:25 PM
8a8mfh's Avatar
Is this clutch ok for a mostly stock car?
Old 03-29-2006, 06:39 PM
8a8mfh's Avatar
Well **** it. $111 to ship the **** from GM Performance parts and it still beats any sponsor on this site. $540 total. Thanks guys.
Old 03-29-2006, 06:59 PM
mrhzk35404's Avatar
Did you ever think about the ls7 clutch?
