need help
need help
I put a spec stage 2 in my 98 t/a. When i put the trans in the car it was about 1/4 inch from butted up with the bellhouseing. So i started two bolts and slowly pulled it up. It bolted up with light press but the line that hooks to the slave wouldnt go in. So i backed the bolts off and it went right in. With the trans is still 1/4 inch off the bell houseing so i put the bolts in and it pulled up.I put it all back together and the clutch slipps slightly any ideas
