How many people have shimed their slave?
Old 04-12-2006, 11:29 PM
Bad Blu Formula's Avatar
Default How many people have shimed their slave?
What did you think about the results?
Old 04-12-2006, 11:47 PM
DONAIMIAN's Avatar
Theres is no question, it should have been shimmed when you installed it.
DONAIMIAN's Avatar
And how do you like posting in here instead of the automatic section, lol.
Old 04-13-2006, 12:00 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
I shimmed my slave on the first spec 3 clutch....made the mistake of getting another one after it was toast...then got the adjustable master and was told that I would not need to shim...so I didnt. There was really no difference with the adjustments that I made. Should have gotten a different clutch the second time through though!
Old 04-14-2006, 12:48 AM
When I did the T56 swap there was no shim that I was aware of so its probably not in there. I had removed the slave when I sent it to get rebuilt and I didn't see a shim behind it either. Where does it go anyways?
