question
question
im switching from an a4 to m6 and was curious if there was anybody that makes an aftermarket tranny cross member. ive looked around and didnt really find anythingi have a umi torque arm with drive loop (the tqa doesnt mount to the tranny.)
you guys have any suggestions or do i just need to get a factory one
bmrfabrication.com has one but it has a torque arm relocation bracket on it so the torque arm isn't connected to the transmission itself. I don't know if it will work with stock torque arms or not. You may even be able to cut that bracket off and use it as a normal crossmember. Take a look at it.
