85 Firebird V6 to V8 Conversion w T5 transmission
The ratios are not going to be the best for your V8. Also the torque rating for the V6 unit is approx. 260lb-ft. You will prolly tear up the trans with the V8. Unless it is just a temp install, I would look for the correct T5.
28, 85, conversion, difference, firebird, fit, lq4, manual, t5, trans, transam, transmission, transmissions, v6, v8, weaker
