What Stage is this SPEC Clutch??????
Okay another question I just ordered a flywheel, pilot bushing, and throw out bearing from autozone since I plan on throwing this clutch back in this weekend. Can I use the stock 98 throw out bearing that is on order, with this spec clutch and pressure plate, or do I have to order a TB from spec? Thanks.
Never mind I am going to be ordering the 01 slave from GM Parts Direct, but while I was at the parts store I wasn't sure if the slave came with the TB or not. I ordered the TB anyway just in case, so that the clutch can be put back in for sure this weekend. Thanks anyways.
