Clutch Master & Slave Cylinder Pressure Ratings
Old 04-20-2006, 06:28 PM
mrws6speed's Avatar
Default Clutch Master & Slave Cylinder Pressure Ratings
Ok.....I have a 1997 TransAm with a 6-speed.
I got a SLP Billet flywheel, clutch & pressure plate.
Now....there's chatter in the transmission like the clutch is not fully enguaging.
First Question:
I've heard when you go to a billet flywheel that you sometimes have to change out the master/slave cylinders for stronger ones. Is this true?
Second Question:
Can I go to an '02 TransAm master/slave setup to use on the LT1 setup. I've heard the '02s are the strongest ones. Or are there any aftermarket ones that would be worthwhile?
Third Question:
What are the part #'s for the '02 full master/slave setup?
Old 04-25-2006, 08:30 PM
mrws6speed's Avatar
Bump..............
Anyone?
