Flywheel and Clutch Bolt Sizes
Old 04-27-2006, 09:08 AM
Schitzo's Avatar
Default Flywheel and Clutch Bolt Sizes
Hi guys, I am in the process of installing an T56 in my car but do not have the bolts for the flywheel to block, and pressure plate to flywheel.
Does anyone know what sizes these bolts are and the best place I get them quick.
Part numbers would help to
Thanks
Old 04-27-2006, 06:30 PM
8a8mfh's Avatar
Flywheel to crank are 11mm, you need to get bolts for this from the dealer or aftermarket.
The pressure plate to flywheel are 10mm I think, I got mine from the hardware store, grade 12.9 allen head, I think the length was 1". Just thread a torque arm trans mount bolt in there and take that to match it up.
Quick Reply: Flywheel and Clutch Bolt Sizes
