Is my Ram HD slipping(PLEASE HELP)?
Old 05-01-2006, 03:58 PM
01 BERGER CAMARO SS's Avatar
Default Is my Ram HD slipping(PLEASE HELP)?
I have a D&D performance T-56 with a fidenza flywheel and Ram HD clutch. I installed the MS3 and Stage 1 heads this weekend. Now my clutch is slipping, it starts slipping at 2800 rpms n when it gets to around 4500 or so it kinda grips. Wut could it be?
Old 05-01-2006, 07:40 PM
cantdrv65's Avatar
Question
Clutch is probably toast. Do you have an oil leaks in the rear of the engine?
Old 05-03-2006, 09:21 AM
Well, since you ask that. The passangerside valve cover gasket had messed up and it wus leaking fluid. Was that the problem?
Old 05-03-2006, 09:27 AM
bowtieman81's Avatar
Yep, had a leaking valve cover gasket (well actually the guy never tightened it). It fried my clutch. Disc got oil on it and that was all she wrote. Sorry man.
Old 05-03-2006, 02:07 PM
Stick only's Avatar
It is very possible the issue has to do with the flywheel finish. Fidanza does not grind their flywheels and the inserts are not flat, we have seen it time and time again. Also the slippery finish (not ground) will not properly seat the disc. I would bet this is most of the problem...
Mike
