T56 ratio swap?
Old 05-01-2006, 06:08 PM
Glenn98ZM6's Avatar
Default T56 ratio swap?
i want to swap my 5th & 6th to a more race friendly ratio. are there any options out there? something like a .83 5th and .70 6th?
the car is used for road racing.
Old 05-01-2006, 07:09 PM
NVR_SPDS's Avatar
I got mine from RPM Transmissions. I have .80 for 5th, and .62 for 6th with ALOT of other upgrades.
Old 05-02-2006, 06:38 AM
calhoon's Avatar
It is possible to a certain degree. The overdrives you are looking for come with the 03-04 Cobra T56( also retaining the 1-4 ratios). You can also get close to those OD ratios with an aftermarket model T56 but the 1-4 ratios will also change. To build these into your Fcar castings should be left to a trans guy.Bottom line is you can't just throw the different gears in there.
Old 05-02-2006, 07:10 PM
NVR_SPDS's Avatar
I have the stock 1-4 ratios, with the 5th/6th i posted before.
Old 05-07-2006, 07:46 AM
calhoon's Avatar
Unless you had gears made, you have a Cobra set and a shortened 03/04 Cobra output shaft to get it to fit in an Fcar casting set.This is not really a do it at home build.
Old 05-08-2006, 04:54 PM
NVR_SPDS's Avatar
Heres the specs on my trans, Built by RPM Transmission:
Gear Ratios: 2.66/1.78/1.43/1.00/.80/.62
RPM 30 spline mainshaft conversion - same as the Viper
RPM 26 spline Viper input shaft - bigger diameter than stock
Full micropolish by Performance Metal
Cryo treated by 300 Below
G-Force solid keys 1-6 gears - replaces stock stamped keys
Heavy duty steel 3-4 shift fork
RPM 1-2 modified shift fork - steel insert
New compressed carbon particle blocking rings
RPM bronze fork pads - replaces stock plastic pads
All new bearings and seals
All clearances set to race specs
Includes correct driveshaft yoke
Quick Reply: T56 ratio swap?
