5th gear?
Old 05-03-2006, 06:38 PM
greatwhite1's Avatar
Default 5th gear?
Well I just turned 25,000 miles on car today, not a daily driver. ? is today car will not go into 5th without grinding in it, what could cause this? Any advise
Old 05-10-2006, 08:31 PM
Well just got it repaired for all to know. The problem turned out to be a plastic wear part on the fork going bad the stripping the gear, cost for the repair $2500.00
Old 05-10-2006, 09:04 PM
jinxedz's Avatar
you paid $2500?
Old 05-11-2006, 08:08 AM
calhoon's Avatar
Worn fork pads> poor gear engagement> gear jump out> clashing shift> permanent damage to fork(bend) and 5th drive gear( the clutch teeth). Its what happens when you don't address a concern when it first comes arround. The pull , teardown and replacement of the synchro assembly, drive gear and shift fork along with the install - 2500 is still high but not outlandish.
