HELP! bellhouseing torque
Old 05-05-2006, 06:13 PM
mukyluk's Avatar
Default HELP! bellhouseing torque
looking for the torque specs for the bellhouseing to motor bolts. i cant find it in any of my manuals! trying to get this damn thing all put back together tonight.
Old 05-05-2006, 06:41 PM
bigdsz's Avatar
I think it is 32#'s, but not positive. I'll post back in a a while, I have a manual in my shop. You do have to be very careful, because I have a couple wrung off.
Old 05-05-2006, 06:55 PM
Keysplayr's Avatar
I couldn't find them either. One guy in here said he just put a little extra "***" into those bolts.
I would also like to know the torque specs for the Bellhousing & the Tranny to Bellhousing torque specs AND should we use locktight on them.
Old 05-05-2006, 07:05 PM
bigdsz's Avatar
Bad luck, I couldn't find the torque either. I did find transmission to bell housing and that was 26#'s and that bolt is larger than the bell housing to block bolt. I must have been thinking iron block at 32#'s. Sorry.
Old 05-05-2006, 07:06 PM
Orange99Z's Avatar
I just tighten mine - no locktight and no problems. I had the tranny in and out 3 or 4 times now and the bolts have always been tight.
Old 05-06-2006, 05:49 PM
P Mack's Avatar
I used 36 ft lb.
Old 05-06-2006, 06:18 PM
sickss228's Avatar
The factory spec is 35 ft lbs
Quick Reply: HELP! bellhouseing torque
