Race shifting questions
Old 05-09-2006, 12:58 AM
bullet099's Avatar
Default Race shifting questions
I recently raced my buddy who owns a 98 Mustang GT with some mods. He always beat me off the line because my tires would always spin too much. Don't worry I caught up and passed him in no time after that. Is there a better way to start off in a race? I can't seem to stage it at all without the tires smoking up like crazy. Any tips?
Old 05-09-2006, 03:45 AM
ninetres's Avatar
Doesn't sound like a shiting question, BUT:
maybe you need new tires......for a start. My 275 18s KDW IIs don't hook for **** in 1st or 2nd. I have 4.10 gears though.....makes it harder. Also might want to start reading up in the suspension forum!
Good luck
Old 05-09-2006, 04:50 PM
jermzz's Avatar
staging your street tires is a waste of time. You're actually making them do the oposite of what their designed to do.
do just a small spin to clean off the tires and just launch from almost an idle and then punch it. your car shouldnt have enough power to spin the tires once the car has started moving. it sounds to me like youre launching from too high an rpm. if its just a 98 gt then this should be plenty for you to rocket past him off the line.
if youre not doing a burnout, not launching and youre still spinning the tires maybe you have some pinion angle issues?
Old 05-09-2006, 05:48 PM
lt1_man's Avatar
I have a quick question I dont want to steal the thread, but what rpm is it safe to really get on it in first? It seems like I never get any traction no matter what rpm iam in in 1st. And its a stock car with stock gears.
-Brandon
Old 05-09-2006, 07:05 PM
ninetres's Avatar
-Brandon
New tires, or you have an issue with your pinion angle like mentioned above.
I can't imagine a STOCK, 3.42 geared, full weight SS or Z28 having traction issues across the board in 1st gear. Sounds fishy.
Old 05-09-2006, 07:20 PM
8a8mfh's Avatar
It sure doesn't
Old 05-09-2006, 07:22 PM
lt1_man's Avatar
See I just put on new some new tires. I know they arent the best but they shouldnt be losing traction like they are.
-Brandon
Old 05-09-2006, 07:55 PM
jermzz's Avatar
Originally Posted by 8a8mfh
It sure doesn't
Old 05-09-2006, 08:25 PM
DONAIMIAN's Avatar
If you werent on a stock clutch I would recomend slipping it for a few seconds off the line, but since it seems like your still on the stocker I would recomend against that.
Old 05-09-2006, 09:37 PM
GETGONE's Avatar
You HAVE to slip it if you hope to launch and not go up in smoke. I have 160 runs on my car with the stock clutch and NO issues. EASE into the clutch from about 1800 RPM on street tires and progressively give it more throttle as you ease out of the clutch. Once you've released the clutch you can floor it. I've gotten 1.98 60' times with this techinque on stock Goodyear F1's at 32psi. If you're street racing the same thing applies. You need to bog the car some then stomp on it unless you like sitting and spinning all over the place.
Quick Reply: Race shifting questions
