Clutch engages different at WOT
Old 05-14-2006, 12:45 AM
ravensfan's Avatar
Default Clutch engages different at WOT
Just like the title says....Normal driving, its great. It engages about 1/3-1/2 of the way off the floor. BUT when I get on it, and go WOT, the clutch engages literally as soon as I start bring the pedal up. Probably about 1/4 of the way up...There is zero clutch slippage. It grabs great, but its just way too soon...
Im leaning towards changing out the clutch fluid. Ive got almost 49k miles and the fluid is pretty dark. Ive also read about wrapping the fluid lines...
Anyone had this issue, if so what did you do?
Old 05-15-2006, 07:06 AM
ravensfan's Avatar
anyone?
Old 05-15-2006, 05:47 PM
ravensfan's Avatar
someones got to have had the same issue before
Old 05-15-2006, 05:51 PM
93formulabird's Avatar
Clutch always grabs quicker on high rpms shifts, at leaste it feels that way.
Old 05-22-2006, 07:32 PM
BigJoeBob1's Avatar
Fluid is getting warm and the clutch is not releasing very far from the flywheel. Try some new fluid and a good bleed
Old 05-24-2006, 09:30 PM
ravensfan's Avatar
Exactly what I was thinking....I will update when I do this with results
Old 05-25-2006, 08:36 AM
lsp408's Avatar
drill mod!!!!
Quick Reply: Clutch engages different at WOT
