New Clutch Fried?
New Clutch Fried?
I just put a 403 in my C6. Brand new flywheel and RAM HD clutch. Installed the slave spacer and everything went together smoothly. It seems taking off easy if fine but while criusing if you roll into the throttle the clutch slips. I The car has like 5 miles on it all VERY easy. Will this thing bed in and grab or do I need to take this thing apart again? Like I said I couldn't even tell there was a problem till I took it out and gingerly rolled into it at 45mph.
Steel RAM flywheel, cleaned all the protective coating off with brake cleaner before install.
