Tranny removal with longtubes
Can the transmission be removed in a 6 speed ls1 f-bod with long tube headers still in place?
It looks fine except for the part of the bellhousing where the starter goes...it looks like it will hit the header. The header hangs over this area about 1/4 inch.
Anyone know for sure?
thanks a lot
thanks a lot
wrencher
I run into more problems w/ the Y pipe. The trans tail is right there.
You unbolt the trans from the bell housing remove it. Then you take the bell off the block to access the clutch.
