aftermarket bellhousing?
Old 05-17-2006, 08:15 AM
ace68's Avatar
Default aftermarket bellhousing?
MCCloud or other brand scater shield(bellhousing) I have been checking it out however it looks like you need a differant trans for it or it going to work on an LS1 with factory t-56? The one I was looking at appears to be for a differant trans with a clutch fork and not the hydo setup that is there now? anyone running an aftermarket bellhousing for safty?
Old 05-17-2006, 08:33 AM
calhoon's Avatar
Mc Cleod has generec parts that adapt to all the current T56 applications. Yes it will work with your T56.
Old 05-17-2006, 11:51 AM
ss2000's Avatar
i have the mcloed. other than having to grind a section on the back of the block and maybe opening a few bolt holes a little bit, it was a direct fit. the grinding isn't as bad as it sounds, and there is a write up or 2 on here. it is an sfi part, but it is about 30 pounds heavier.
Old 05-18-2006, 08:03 AM
ace68's Avatar
thanks guy's I didn't know for sure if it would work I don't mind alittle modification to make it fit and the weight will be worth it for pice of mind.
Quick Reply: aftermarket bellhousing?
