what is wrong with my cutch
Old 05-18-2006, 01:13 PM
blown2kss's Avatar
Default what is wrong with my clutch
I recently picked up an 01 zo6, and after beating on it a few times it doesn't like to go into 3rd gear when shifting hard. The shifter goes into the 3rd gear slot but will not engage. I have to take it out of gear and put it backin gear nice and gentle for it to grab. But why would it only do this in 3rd gear.
Old 05-18-2006, 01:45 PM
LS1powerhouse02's Avatar
possibly a shift fork bent?
Old 05-18-2006, 02:27 PM
blown2kss's Avatar
I had that happen to my 00 camaro but that made 3rd gear grind..
Old 05-18-2006, 03:34 PM
the fact that it only happens going into third makes me believe its SOMETHING to do with the tranny.....i dont think it would be the clutch.....but thats just my opinion. Hopefully someone else will chime in here and help.
Old 05-18-2006, 04:22 PM
blown2kss's Avatar
thanks for the replies.
Old 05-19-2006, 12:06 PM
blown2kss's Avatar
anybody else want to put in there 2 cents.
Old 05-20-2006, 04:33 AM
02Z28LS1's Avatar
it's pissed off at you because you called it a cutch instead of a clutch
but then again, i'd be pissed off if someone called me a *****, too
Old 05-24-2006, 08:37 AM
blown2kss's Avatar
One of these days I will learn how to spell, but not today.
Old 05-24-2006, 09:47 AM
calhoon's Avatar
Without a feed line drill mod it can produce the problem you have . Mine would enable a 1-2 shift but restrict a quick 2-3 shift.
Old 05-24-2006, 09:52 AM
TurboGibbs's Avatar
I vote bent fork or broken keys causing the outer slider to hang up. Common for an abused tranny.
Old 05-24-2006, 10:45 AM
OneFast97Z's Avatar
Agreed... bent shift fork... thats what happen to mine before it started to grind and then fourth gear went out on me as well
Old 05-24-2006, 10:51 AM
MrDude_1's Avatar
if it goes into gear normally, but doesnt want to go in after a fast 1-2 shift, then its the restrictor in the line screwing with you...
if it does it all the time, then its a internal trans issue. probly bent fork.
Old 05-24-2006, 11:58 AM
blown2kss's Avatar
when shifting normally it goes in everytime, but on occasion when I do a fast 2-3 shift is when the problem occurs.
is that restrictor issue a quick fix, or does it require a lot of work. that would be my first attempt at resolving this problem. I want to stay away from tearing down the trans until I need to.
Old 05-24-2006, 02:13 PM
MrDude_1's Avatar
do a search for the term "drill mod" on this board, and you'll find a half dozen how-tos.
basically, GM put a restrictor in the line. because of this, when you release the pedal, all the fluid doesnt come back. if you follow one shift with another (1-2 then the 2-3) the clutch doesnt fully disengage, and its a total bitch to get it in gear.
if you take the line off and drill this restrictor out, it helps.
Old 05-24-2006, 04:36 PM
blown2kss's Avatar
I heard of the drill mod, so this could be the problem with my clutch.
thanks.
Old 05-24-2006, 06:53 PM
Keysplayr's Avatar
Didn't 01 Zo6's come with steel shift forks? Kinda hard to bend those puppies if they are indeed steel and not alum.
Old 05-24-2006, 09:28 PM
ZoFastSS's Avatar
Did you upgrade your slave and master cylinders, and do the drill mod?
Old 05-25-2006, 07:38 AM
blown2kss's Avatar
I haven't modified the car at all.
yet...
Quick Reply: what is wrong with my cutch
