Need help with Reliease/relief bearing spring!!!
Old 05-23-2006, 03:55 PM
JD_Z28's Avatar
Default Need help with Reliease/relief bearing spring!!!
I am installing a new ls1 motor I can't seem to get the engine against the tranny because the release bearing spring pushes the engine back. Does anyone have any ideas on how to fix or get around this?
Old 05-23-2006, 04:00 PM
keliente's Avatar
I posted in your other thread in the gears section...Try walking it in slowly with longer bolts if you can.
Quick Reply: Need help with Reliease/relief bearing spring!!!
