LS7 clutch and stick tires, who's done it?
Old 05-30-2006, 09:28 PM
My90Iroc's Avatar
Default LS7 clutch and sticky tires, who's done it?
I'm curious if anyone has used the LS7 clutch with any type of tire yet? When I go to the track in the fall I want to know how much tire I can get away with using this clutch?
Old 05-30-2006, 09:42 PM
HowellSoccer88's Avatar
Just on Nitto DRs dropping from 3ish...still on the 10 bolt though so its getting treated kinda nice.
Old 05-30-2006, 10:05 PM
blackrat's Avatar
I have nitto dr's on the back and to tell you the truth I can't get the damn thing to chirp second no matter how fast I shift, although I think that's partly to blame on the flywheel.
Haven't launched it thought yet, I have an event coming up and I don't want to blow my diff before then.
Old 05-30-2006, 10:39 PM
Project GatTagO's Avatar
Received 1,384 Likes on 873 Posts
Why do you want it to chirp? That means your breaking the tires loose. You WANT traction...duhhhhh!
Andrew
Old 05-31-2006, 01:00 AM
Chris81's Avatar
I'll be doing ALOT of beating on mine as soon as it goes in with the heads/cam stuff..
Old 06-01-2006, 07:05 PM
blackrat's Avatar
Andrew
Well yeah, but it kind of bothered me that I could get it to chirp with my old ls6 clutch but couldn't do it with my ls7 clutch, which should be a little grabbier, no? However, I remember when my friend did his upgraded clutch and aluminum flywheel to his integra and couldn't get the thing to chirp anymore, so I figure it's due to the less weight in the rotating assembly of the clutch/pp/flywheel. At least hopefully, and isn't the clutch not grabbing as hard as it should.
Old 06-01-2006, 07:29 PM
The things you and your friend are concerned about have nothing to do with making a car go faster. If your worried about chirping the tires and doing smoky burnouts, why bother with a good clutch? Get yourself a stock clutch, some cheap hard tires and have at it. You will chirp in every gear. None of that will make you faster...
Andrew
Old 06-01-2006, 07:37 PM
yekta's Avatar
I wanna hear from Road Racing Drivers, the tires they ran and their hp pls...
Old 06-01-2006, 08:22 PM
chevym3's Avatar
where did you get the ls7 clutch. I have been looking to buy one. THANKS
Old 06-01-2006, 08:56 PM
HartAttack's Avatar
T56REBUILDS.COM
talk to amber or jason.
Old 06-02-2006, 07:58 AM
M6HTZ's Avatar
Any 60' times with the clutch?
Old 06-02-2006, 08:44 AM
GuitsBoy's Avatar
Andrew
It dosnt help him go any faster to have the clutch slipping and converting your horsepower into heat energy. Granted, breaking the tires loose wastes energy and wont be as fast as a clean shift, but a slipping clutch also absorbs energy. Id prefer to have a grabbier clutch and give myself the task of not spinning the wheels.
Old 06-02-2006, 08:56 AM
trembles's Avatar
I Run The Ls7 Clutch And 4.10 Gears 255/50/16 Mickey Drag Radials And Dump The Clutch At 5k With Just A Cirp, I Love The Clutch
Old 06-02-2006, 09:00 AM
785T/A's Avatar
Will the LS7 Flywheel work in an f body with the LS7 clutch? It wont in an 04 GTO. So i hear.
Old 06-02-2006, 09:02 AM
GuitsBoy's Avatar
The ls7 flywheel is teh same as the ls2 flywheel. Same part number. It will work in an f-body. The o4 GTO probably needs the GTO ls2 flywheel, but im not certain.
Old 06-02-2006, 12:43 PM
yekta's Avatar
what I read is F-bodies need to get corvette LS2 flywheel, not GTO LS2 flywheel
Old 06-02-2006, 12:45 PM
yekta's Avatar
Damn Are you serious? That sounds great, how much hp and torque ur car has? or thos are the only mods u have? I need more information pls
Old 06-02-2006, 01:07 PM
Shamson5.7's Avatar
Correct.
Old 06-02-2006, 03:19 PM
trembles's Avatar
The Car Has 150hp Nitrous , Borla, Gran. Lid,
Old 06-02-2006, 06:09 PM
HartAttack's Avatar
so how did it handle the bottle?
Quick Reply: LS7 clutch and stick tires, who's done it?
