just bought new clutch, what else do i need?
Old 06-03-2006, 12:03 PM
405hpta's Avatar
Default just bought new clutch, what else do i need?
like it says, i just bought a ram powergrip hd with the 910 disks and the billet flywheel, my stock clutch is pretty much fried. i am wondering what else is there that i can do/need to do to make the clutch/trans system better and stronger while the transmission is out of the car so i don't have to go back later and do it again. any help is greatly appreciated. thanks!!
JM
Old 06-03-2006, 12:57 PM
mrhzk35404's Avatar
slave cylinder, maybe a new master or do the drill mod. Make sure you find out if you need a shim for your slave.
Old 06-03-2006, 02:11 PM
Keysplayr's Avatar
If this is the car in your sig (2000 TA) then update your master and slave cylinders.
Change the pilot bearing, and a new throwout bearing (can sometimes come with a new slave cylinder).
USE RED LOCTITE on Flywheel bolts and pressure plate bolts. Torque them to specs from the manufacturer.
Old 06-03-2006, 07:57 PM
nickls1's Avatar
how many miles are on the car? a rebuild to make the trans stronger could be helpful while its out anyways. I have heard t56rebuilds.com does a rebuild in a week or so and is good for pretty high power output.
