Whining on T-56
Whining on T-56
my tranny is whining and i have no f***ing clue why. only has 46k miles and wasnt doin it until i had a trans mount made of hyperflex, and a B&M shifter installed. wtf? why all of a sudden it wants to start whining like a bitch? any input?
Originally Posted by Fran D
If the B&M replaced the stock shifter, then the lack of the rubber isolator my just be propagating more sound into the passenger compartment. This happened to me when I changed the stock handle (and isolator) to a "short-stick." More noise, but it wasn't hellish. Beyond that, is the fluid level OK?
When you take away stock sound-absorbing components, more noise enters the cabin. Put the stock stuff back on and I guarantee the noise will cease. You've either got to live with it, or go back to stock.
yea tru. i juss looked at the stock shifter and moved it around. the bushing does look like it would kill the sounds/vibrations. but what about the hyperflex tranny mount? will that cause possible damage to the tranny due to stiff vibrations? should i put the oem factory mount back on?
