Clutch fluid replaced
First the symptoms.....The clutch pedal just felt too light. I didnt feel like it had as much pressure as normal. Normal driving, the engagement was fine. But at WOT it engaged very quick, almost right off the floor...
I checked the clutch fluid and it looked like black muddy water Took it to my mechanics shop and had it flushed out and new fluid put in.
The results were awesome. The clutch engages alot more normal under WOT. And the clutch pedal itself has more pressure to it
