Clutch for T56 and 800+ WHP?
Which clutches are you guys making big power running? I am pulling my tranny with the motor in a few weeks and need to decide which clutch/flywheel I want for my build.
Its going to be mated to a 408 with an F1C Procharger that should make over 800RWHP without any problem and on spray over 1000rwhp.
So which clutch do you guys recommend?
I was thinking about getting a Spec Stg 5 because I love my Spec stg 3 clutch I have now, but I also know that the Spec clutches are so hit or miss that it may not be worth it.
Suggestions?
Suggestions?
my spec 5 holds pretty good, easy to drive, but its got the squeel on take off. its seems to come and go, depending on the day. hopefully with more miles it will go away. in the meantime i rev a lil higher and that seems to take care of the squeel. got about 900 miles on it
