hard clutch pedal stickin low!!!
Old 06-20-2006, 11:43 AM
ski23's Avatar
Default hard clutch pedal stickin low!!!
hey guys, 01 ss with 55k miles. a few weeks ago i looked in my hydraulic res. to scope the fluid. well it looked grey and dirty compared to my uncles. i used a old windex bottle to suck 3/4 of the fluid out and replaced with new fluid drove for a few days and did it again. repeated 3 times now. not sure if i caused the clutch problem or if its on its way out/ need drill mod. last couple times ive gotten on it the pedal gets real hard and real low to the floor. last few days i got on it a couple times and seems that the car dosnt pull as hard as it use to. any suggestions? maybe i got some air in the lines? didnt have any trouble till i replaced the fluid. thanks in advance
Old 06-20-2006, 12:02 PM
chadtx01's Avatar
Do you have headers?
Usually if the fluid is dark, its because its getting cooked because the hydrolic line is too close to the headers. I had this problem. I heat wrapped the hydrolic line and started running DOT 4 fluid instead of DOT 3 and I havent had any problems since.
Old 06-20-2006, 01:43 PM
ski23's Avatar
no headers, fluid was dark dark gray. peservior walls are dirty,but fluid is clean
Old 06-20-2006, 10:01 PM
ski23's Avatar
ttt, anymore opinions?
Old 06-21-2006, 01:38 PM
Summit2345's Avatar
had same problems had to replace master cylinder. later i took the old master cylinder apart and it was filled with thick black junk. my car only had 17k miles and headers for about 5k miles
Old 06-21-2006, 05:21 PM
BAD2000TA's Avatar
So you didn't need the slave cylinder?? Just the master and 'voila?
Old 06-21-2006, 11:56 PM
Summit2345's Avatar
nope didnt need a slave just a new master cylinder and now its as good as the day i bought the car
Quick Reply: hard clutch pedal stickin low!!!
