Clutch/Transmission
Clutch/Transmission
I just bought a used 2002 Trans Am WS6 M6. It has 84K miles and everything is still stock. When in first gear and you are hitting the engaging point it seems to want to slip. The car doesnt want to get up and go. Once you get it going it takes off. Best way for me to try to explain is it kind of feels like the clutch slips. It engages where it needs to, however at times it is like you have to ride the clutch cuz it doesnt want to take off. Going in and out of 3rd gear is rough and sometimes in other gears when you let off the clutch it wants to jump (small jerk) at the engaging point.
Just two questions:
1) Is it my clutch?
2) Is the LS7 clutch/ LS2 flywheel a good replacement when I replace the clutch and does putting this clutch in the transmission require other mods? Had a guy at a shop today say he wouldnt warranty his work if he did it because doing that requires to many mods.
Thanks everyone for your help.
Just two questions:
1) Is it my clutch?
Originally Posted by 93formulabird
Put it in 6th gear at like 40 mph and punch it, if the rpms go up fast/faster then normal or go straight up. Its the clutch slipping
I tried the 6th gear at 40mph. It seemed to be sluggish. Is that the way its suppose to be? Never had one of these cars so Im not sure. And on the "driver error", I have driven standard for 6 years so I doubt that that is the case. Thanks for yalls help.
Okay I have a question that shows my lack of knowledge. The girl when I bought the car said that one of the vacuum tubes had possible blockage. What is the vacuum tube specifically and could that be the problem or what problems would that cause?
