best adjustable master cylinder? any why is it the best?
I've looked around and all i have seen so far are the Mcleod and the RAM (junk from what i've heard) what other brands are there and which ones are the best, and what makes one better than the other?
the problem with a rebuilt stocker is that it's plastic, just seems to flimsy (sp?) to me. couple guys i talked to said that for any car with big power the stocker is a liability. I think i'll just go with the Mcleod adj. one.
I've heard of the Mcleod breaking a lot. They often sell it with its own rebuild kit due to the fact that it has a good chance of breaking. I've never heard of any issues with the Ram Master.
I have had my Mcleod for a couple of years now on my daily driver and I had to rebuild it twice so far. Inside the cylinder, there are 2 little holes and they have a tendency of creating scratches in the rubber seal evertime you press the pedal up or down. These scratches eventually turns into gouges and the seal start leaking. The end result is when you press the pedal down, the oil slowly leak back inside the cylinder within the uncompressed area causing the clutch to slowly engage.
A rebuilt kit helps fixing this issue but it's only temporary. The design is flawed. these holes should be cut differently so that they don't damage the rubber.
Otherwise it is a good piece.
It is my understanding the Ram is nothing more than a modified stock piece. I personally had Allan at Futral modify a stock unit for me.
