Clutch pedal isnt engaging the clutch????
Old 07-04-2006, 06:20 PM
ls1king's Avatar
Default Clutch pedal isnt engaging the clutch????
ok i have a problem with my clutch... when i push my clutch pedal down about half way it will drop to the floor and it wont come back up on its own... and also it dosent engage the clutch when i do push it to the floor... what could it be and how could i fix the problem?????? thanks joe
Old 07-04-2006, 07:26 PM
tripps's Avatar
does it do this problem whenever you are shifting at higher rpm's (racing or haulin ***) ? if it is, then your answer could be in this thread: https://ls1tech.com/forums/manual-transmission/510788-manual-transmission-faq-look-here-first.html
if not, then have the car checked out as your slave cyl might be leaking or going out.
Old 07-04-2006, 07:38 PM
ls1king's Avatar
noo my car doesnt even run yet... it drops to the floor when i push it and it wont come back up and it wont engage the clutch
Old 07-04-2006, 07:43 PM
tripps's Avatar
wow, yeah sounds like a hydraulic problem
Old 07-04-2006, 08:05 PM
ls1king's Avatar
yeah it is i think.. but i need to find out how i can fix this problem...??? u wouldnt kno anyone that would kno would you???
Old 07-04-2006, 08:18 PM
tripps's Avatar
not up in massachusetts. i would suggest asking some people in your area, that have an ls1 or are car enthusiasts, where a good tranny shop is that can give you an estimate and are very knowledgable/do good work.
Old 07-04-2006, 08:25 PM
ls1king's Avatar
not up in massachusetts. i would suggest asking some people in your area, that have an ls1 or are car enthusiasts, where a good tranny shop is that can give you a estimate and are very knowledgable/do good work.
alright thanks
Old 07-05-2006, 01:22 AM
Phlip00WS6's Avatar
You just need to bleed the hydrolics, thats all.
Old 07-05-2006, 10:34 AM
bowtieman81's Avatar
Yep, you have air in the system. Bleed it and should be good to go.
Old 07-05-2006, 10:54 AM
chadtx01's Avatar
Check to see if you have any fluid in the resovoir. If you do, and you can pump the clutch and rebuild some pressure, then I would say you have air in the line.
If you pump the clutch, and you lose fluid and you can't rebuild pressure, I would say your slave cylinder is dead.
First thing, check the fluid level and see where its at and try bleeding the line.
Old 07-05-2006, 10:23 PM
ls1king's Avatar
alright!!! hey thanks alote you guys have been a great help... and u wouldnt happen to have a site that shows me how to do it would ya?? i have an idea but i dont want to mess anything up!!! thanks
Old 07-05-2006, 11:06 PM
Phlip00WS6's Avatar
At the top of this forum, it says manual transmission FAQ all your answers are in there.
Old 07-06-2006, 01:36 PM
ls1king's Avatar
ok thank you!!!!!!!!!!
Old 07-06-2006, 02:39 PM
Sk8runeg's Avatar
Hey I live in Chelmsford, MA and I'm picking my car up today at the local tranny shop. This sounds like your slave cylinder gone ban, seeing that its a 99 I would have that replaced if I were you, I did today. The place I brought mine to seems like a good place, if you want to get the work done there.
Old 07-06-2006, 04:04 PM
ls1king's Avatar
alright cool thanks... im just going to have dezracing do it.. since im brining it there next week... but thanks anyways man!!!
Old 07-06-2006, 06:43 PM
tripps's Avatar
it sounded like a dead slave. good luck with everything
Quick Reply: Clutch pedal isnt engaging the clutch????
