T-56 ?s.
T-56 ?s.
What are the differences between the 94-97 and the 98-02?
Can a Ford tail housing fit a GM trans, and what needs to be done?
How much travel the does the hydraulic cylinder need?
And can the input shaft be exchanged for the Viper's, Fords input shaft?
Can anyone post some pics of the trans?
Thanks.
Thanks.
There are many posts on the LT1 vs LS1 T56s, I suggest you search them out. As for converting Ford T56 , it might be better if you detail what it is you are looking to use this trans in.
