Clutch pressure goes away?
I've noticed something in the past few days. I was on the way home the other morning, and decided it was time for a burnout. So I get it up to about 3k, drop the clutch and on the shift to second there was a lot of free play in the clutch, you know like a dead spot. Then it returned to normal after a few shifts. The today I got sideways around the corner, no clutch dumping at all, and it did the same thing, so I put it in neutral and pumped the clutch pedal a few times and pressure came back after every pump? Am I ******* something up or is something about to go?
Check the fluid level.
It could be air in the line and it needs to be bled, or it could be time for the drill mod.
Either of those are minor.
If they dont work, time to start looking at your master and slave cylinder to see if one of them is dying.
