Drill Mod without Dropping the Trans?
The only thing I would change would be their bleeding procedure. After bench bleeding the master just shove it back into the slave. (put an open ended wrench against the quick release fitting for extra leverage if needed) No need to open the bleeder on the slave. If this is bad to do for some reason let me know, but I can't see why it would be.
