skip shift elim from a 99ss to a 05 vette?
I believe it's the identical plug near the rear of the trans. The one that acutally looks like it would stop it from going in gear. The one you need is located mid ways up.
Black terminal( on the solenoid AND the harness plug) = reverse solenoid.
Located near the shifter"box" on an Fcar.
White terminal= skip shift solenoid
Located on the main case and near the port covered by a steel plate.
