2nd gear grind when speed shifting, rebuild options?
2nd gear grind when speed shifting, REBUILD OPTIONS?
I'm getting a grind when I speed shift seconds gear. The car is mostly stock, and will stay that way for a while, what are my options? particularly cost wise.
You positive its not the operator instead of the tranny??
Had to ask cause I have seen people do this exact thing & it was them lettin the clutch out just a split second before fully in gear. They too thought the tranny was toast.
Does it do it only when your WOT & speed shifting?? Or all the time even if your easy on it??
