Anyone using Fidanza flywheel with McLeod single disc?
Old 07-20-2006, 12:50 AM
GrannySShifting's Avatar
Default Anyone using Fidanza flywheel with McLeod single disc?
Did you remove the dowel pins on the flywheel as there are no provisions for them on the McLeod pressure plate? need to see if customers clutch setup is going to work together or not.
What clutch companies pressure plates have dowel pins?
