More power--Harder to shift?
Old 08-07-2006, 09:56 PM
bensdad's Avatar
Question More power--Harder to shift?
I just had a stout H/C install and am having some issues with W.O.T shifting.Is this because of the power and rpm or do I just need to get used to it? M6 spec stage 3 clutch.
Old 08-07-2006, 10:02 PM
Black FormulaLs1's Avatar
how old is the clutch and pressureplate combo>? how many miles on it BEFORE the HC swap? just curious..could be just worn out.? or a bad slave...i have changed like 6 in my damn formy..
Old 08-07-2006, 10:35 PM
bensdad's Avatar
50k on motor and 25k on clutch. I have to say it shifted just fine the day before the install of h/c.
Old 08-08-2006, 06:47 PM
bensdad's Avatar
Anybody else have this problem?
Old 08-08-2006, 08:45 PM
TLUZLS1's Avatar
What year is your car, might be bad slave/hydraulics?
Old 08-08-2006, 09:09 PM
Kleeborp the Moderator™
MeentSS02's Avatar
If you bumped up the rev limiter (which is almost inevitable with a cam install), shifting at higher RPMs (above the 6200 RPM factory rev limiter) will show you the shortcomings of your hydraulics and/or clutch setup. If you haven't done the drill mod to the master, I'd start there...if you don't have the upgraded hydraulics (that came standard on the 2001-2002 F-bodies), that could also be another thing to look into.
Old 08-08-2006, 09:22 PM
TLUZLS1's Avatar
My thoughts exactly.
Old 08-10-2006, 04:46 PM
bensdad's Avatar
Thanks
Quick Reply: More power--Harder to shift?
